Posted December 8, 2016 Hey all, I'm intrigued to know; would you rather find a quick and easy way to get around a problem within IT or would you rather fix it outright even if it takes ages to find and implement a solution? Usually I'd find a quick way that I can implement multiple times but other times I do have to actually think I'm interested to hear everyone's opinions - Jack Don't forget to @me / quote me for a reply =] Link to comment https://linustechtips.com/topic/703830-it-problems/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 8, 2016 22 minutes ago, JackHubbleday said: Hey all, I'm intrigued to know; would you rather find a quick and easy way to get around a problem within IT or would you rather fix it outright even if it takes ages to find and implement a solution? Usually I'd find a quick way that I can implement multiple times but other times I do have to actually think I'm interested to hear everyone's opinions - Jack depends on the issue, if it needs to last or if it's needed back up and running asap and can be worked on later after it isn't need so badly Yours faithfully Link to comment https://linustechtips.com/topic/703830-it-problems/#findComment-8996186 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 8, 2016 simple, first I would take the quick work around to make it seem solved to public/users and then in the meantime look for a way to solve it definitely. May the light have your back and your ISO low. Link to comment https://linustechtips.com/topic/703830-it-problems/#findComment-8996189 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 8, 2016 Depends on the situation if the issue is customer / user facing, and people are going to be affected, a quick fix is required, followed by a in depth look to stop it happening again if the issue is not customer / user facing then there is more time to go into detail for the long term fix If its a personal machine i take the time to fix it fully to ensure it wont happen again Link to comment https://linustechtips.com/topic/703830-it-problems/#findComment-8996374 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
