Partition Help
Solved by samcool55,
easeus partition magic ![]()
The trial should do the trick, i know it might look a bit weird but it does work as it should.
I've used it multiple times in the past and it never let me down, some operations take a while but that's about it.
edit: it is a bit risky but the issue is that there is a partition between the unallocated part and D:
What you should do is move that partition somewhere else so the unallocated hdd and the D: partition are next to each other.
