Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/
TBH, something like this is probably more than adequate. I used this for years outside my house. https://www.amazon.com/Steren-Cat-5E-Cable-Crossover-13909/dp/B00BFU9ITS
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8994840
1 minute ago, djdwosk97 said:
TBH, something like this is probably more than adequate. I used this for years. https://www.amazon.com/Steren-Cat-5E-Cable-Crossover-13909/dp/B00BFU9ITS
wow 1,000ft. I will need to learn how to crimp but that shouldn't be hard
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8994847
crimping is pretty easy. afaik, it's not rated for outdoor use, but I didn't have any issues during the 5+ years it was used.
PSU Tier List | CoC
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8994852
ok well if it breaks just run a new section. Any special crimping tool or will a normal wire stripper work
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8994860
One of these will probably work fine: https://www.amazon.com/Belkin-RJ45-Medium-Duty-Crimp/dp/B00004Z62S Although I used an Ideal one (and an Ideal tester).
PSU Tier List | CoC
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8994875
@GDRRiley thinking back on it, there might not have been any 5E cables running outside my house. I know there was RG6, but I can't remember for sure if there were any 5E cables.
PSU Tier List | CoC
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8995028
22 minutes ago, crowy said:
If you're running cables through pipes/trenches, you probably won't need specific outdoor cables.
it will be outside not in a pipe for a while then cross between my house and the back building and run outside for some time.
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8995086
so I should just get this https://www.amazon.com/Outdoor-Waterproof-Shielded-Ethernet-Direct/dp/B001B6C5H8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1481166298&sr=1-1&keywords=outdoor%2B150%2Bethernet%2Bcable&refinements=p_89:Ultra%2BSpec%2BCables&tag=linus21-20 ?
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8995088
As far as crimpers go, I've got this one and it's pretty good. https://www.lowes.com/pd/Southwire-Data-Crimper/50238801
CPU: Ryzen 9 5900X @ 4.7GHz | GPU: EVGA RTX 3080 | Motherboard: X570 I AORUS PRO WIFI | RAM: G.SKILL Trident Z RGB 32GB | Case: NCase M1 v6.0 | SSDs: Samsung 970 Evo+ 1TB, 860 Evo 1TB | CPU Cooler: H100i ELITE CAPELLIX | MonitorsLG 27GN950-B 4K 165Hz |
https://linustechtips.com/topic/703709-outdoor-ethernet-cable/#findComment-8995180
