Stream PC content to a Smart TV
By
Guest
in Displays
in Displays
Solved by EunSoo,
You could try using Miracast, or Intel WiDi if your devices support it. If you have a spare computer or raspberry pi then you can use moonlight. If you're willing to spend some money then a Chromecast will be the easiest option.
EDIT: for Moonlight your PC needs an Nvidia Gamestream compatible GPU
Featured Topics
halfbood_drag0n ·
2
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
