Hi @Dropndestroy213.
From what I can see, the M.2 model is again a SATA drive. So, if your motherboard has an available M.2 port, you can go with either option. It's just a matter of form factor, the interface is still the same. The performance should be the same as that of the 2.5" drive.
Hope that helps.
Boogieman_WD
WD Representative
http://www.wdc.com
https://linustechtips.com/topic/703416-help-with-2nd-ssd/#findComment-8996106
