So where I live there are not much choices to get so its Ek stuff so yea there are the parts I hope its all alright
EK-CoolStream XE 360 (Triple)
EK-Supremacy EVO - Full Nickel (Or. CSQ)
EK-XTOP SPC-60 PWM - Plexi (incl. pump)
EK-RES X3 150
EK-Ekoolant EVO UV BLUE (premix 1L)
EK-ACF Fitting 13/19mm - Blue
EK-AF Angled 90° G1/4 Nickel
EK-HDC Fitting 12mm G1/4 - Red
Pch A Crystal Clear 9,5/15,9mm RETAIL
Is this all good for the system or I missed something or dunno first time btw ;(
well make ur dreams come true
https://linustechtips.com/topic/703371-first-time-custom-water-cooling-help/
I am kinda confused by your fittings.
13/19mm Soft tube Compression
12mm Hard Pipe Compression
Are you mixing your Tubing?
I would actually advise going with soft tubing the first time if you don't care so much about the awesome look of hard pipe.
Make sure your hard pipe fittings match the OUTER diameter of your tubes
Make sure your soft tube fittings match both INNER and OUTER diameter of the tubes
for 9.5/15.9mm tubes (that are weird measurements and very thick walls) you need a 9.5mm (possible 10) / 15.9mm (possibly 15.5)
I would recommend however to get your fittings and tubes from the same source, this ensures that they are tested to properly seal (ek has both soft and hard tubes)
Have fun and good luck :)
Make sure to share some pictures and dont hesitate to ask if you have any further questions
You have two of the same posts up, make sure you respond to both.
thanks
