Socket temps - do they matter?
Hi,
I have a FX 8350, currently at 4.8GHz. I have a Noctua NH-D15 cooler on it, probably the best aircooler on the market (it's so damn huge).
My core temps are fine, at about 58°C while priming, but my socket temp is at 73°C which is already 3°C over the AM3+ specification. The only way I can cool it down is to put a fan behind the socket (I tried that, pushes the socket temp down for around 7°C), but is this necessary? I'm now on pretty low voltage, at around 1.375V and I wonder how all the other FX 8350 guys can push the voltage even higher with similar cooling (H100i e.g.) without burning the socket.
What do you think, guys?
Greets,
Andy
EDIT: I have an ASUS M5A97 R2.0 evo mainboard.
https://linustechtips.com/topic/703342-socket-temps-do-they-matter/
Well, it's an AMD chip so your cooler is just stopping it from a thermal meltdown. But those are fine.
You also have to think of the rooms ambient temps. It will vary a lot.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
Ambient temps are now around 21°C (winter here). In summertime I will have to lower the overclock for sure, currently I'm living in an apartment beneath the roof, so it's getting really hot in here (30°C+). I just want to get the maximum performance out of my system, because currently I don't have the money for upgrading the main parts, or to be precise: my girlfriend would kill me. xD
my laptop (AMD A4-3305M) is getting 100 C when render file in fl studio
and get about 85-95 C when play 720p video
is that fine?
i already change the thermal paste and clean the fans and fins :)
but the problem still exist
the ambient is 28-34C in here
1 hour ago, Dutch-stoner said:
Dump the GF. With the money you save, you should be able to get a brand spanking new high-end gaming pc. (and you won't risk getting killed)
Not an option. I like my computer a lot, but my girlfriend is prettier and there are things that would hurt if I did them with my computer. 9_9
Yes, socket temp matters. Max socket temps should stay below 72C. It should throttle your CPU if the temp exceeds that.
You can either put a fan behind the socket and/or put a fan on the VRMs.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Okay, I'll go with the "backside fan" then, because there is no room left for a fan for the VRMs because of the Noctua. Maybe I'll post some pictures, if I don't forget to take some :S
