Compatibility issues ?
Go to solution Solved by -rascal-,
30 minutes ago, Dilen futch said:
I have a  potential build  in the works I'm wanting to use the intel core i7 6800k 6 core however I just bought the MSI X99A SLI PLUS motherboard  it matches up with the chipset  but I think that there has to be an update of some kind  I want to know exactly what I have to do before I buy my CPU. Any help? https://pcpartpicker.com/user/futch/saved/Jdvf7P
The MSi X99A SLI PLUS first launched with Haswell-E (e.g. i7-5820K), so PCPartpicker, will give a warning sign.
In most situations, the motherboard should have no problems working with the the i7-6800K out of the box -- the manufacturer will typically load a more recent BIOS onto the board (they know the feels). It may not be the latest BIOS available, but it will work. If you are buying from a place like NewEgg, NCIX, SuperBiz, directly from Amazon, where their supplies go in and out pretty quickly, you should be okay.
Of course, if you buy from a local store or some sort, then it COULD be an old stock motherboard....in that case, it MAY still have a old BIOS version on it (e.g. does not support Broadwell-E out of the box).
27 minutes ago, Hal_9000 said:
You will need a previous CPU to update the BIOS on the motherboard to use the Broadwell-E processor(6800k).
A quick Google search yielded this.
On a side note 6800k comes with a stock cooler?
No the i7 Extreme CPUs do not come with a CPU cooler; just the chip itself.
I jut got my i7-6800K from the UPS delivery guy yesterday (along with my X99 motherboard and PSU).
https://linustechtips.com/topic/702977-compatibility-issues/
4 minutes ago, Dilen futch said:
I have a  potential build  in the works I'm waiting to use the intel core i7 6800k 6 core however I just bought the MSI X99A SLI PLUS motherboard  it matches up with the chipset  but I think that there has to be an update of some kind  I want to know exactly what I have to do before I buy my CPU. Any help? https://pcpartpicker.com/user/futch/saved/Jdvf7P
CPU: I7 5820K@4.0Ghz | Mobo: ASRock X99 Extreme4 | Ram: 4 x 4Gb G.Skill Tridentz@3200Mhz | GPU: XFX 390x | Cooling: Corsair H115i | PSU: Corsair RMX 850x | Storage: Samsung 250Gb 850 EVO + 2tb Seagate HDD | Case: Inwin 805 | Keyboard: Tesoro Gram Spectrum | Mouse: Tesoro Gram H3L | Mousepad: Corsair MM800 RGB  | OS: Windows 10
https://linustechtips.com/topic/702977-compatibility-issues/#findComment-8985321
It will depend on when the board was manufactured.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/702977-compatibility-issues/#findComment-8985408
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/702977-compatibility-issues/#findComment-8985409
Thanks man and ya I got it from newegg and it is sick af
https://linustechtips.com/topic/702977-compatibility-issues/#findComment-8987353
