Hi, my name is Khai from Malaysia. I'm new in this forum and I need help, regarding my laptop display.
My laptop is Dell Studio 1435.
I'm not sure if this is the correct place to post this.
A little back story to my laptop. This is my first laptop that been given by my dad when I was 19. The laptop was previously used by someone in his company, and after fresh format. The new owner is me.
The problem started couple years back then when the screen start showing few white lines in the middle of the screen. The problem escalated from few lines to covering up the whole display with flashing white lines. That's when I decided to sent my laptop to a repair shop. The owner of the shop said it was the LCD display was not functioning properly, due to my lack of knowledge (and ignorance:/), I decided to believe anything what the man said to me. Thus, it cost me MYR800 (more or less), with 2 month of warranty.
Well, my laptop when back to normal, no white lines whatsoever. But, only for 2 months :|. The laptop worsened. Back then, laptop was a necessity in a university for assignments, reports, quizzes,  annnnd some LAN party9_9. My sister, apparently had a laptop to spare. A Dell Vostro 1320, which I'm still using up till now (I'm 23 btw).
Little by little in my free time I'm figuring what went wrong with Dell Studio. Through some research and discussion (and dusting off) with Mr. Google and few of my friends. I have disassemble and re-assemble my laptop. What I have gathered, the problem lies either with the inverter or wiring. So, before I make any unnecessary purchases of parts for the repair. I need another opinion regarding with my predicament.
This is my beloved Studio 1435. When the "flashing" occur, the display will suddenly hang(not sure if this the correct term) first, then the "flashing". The display is full of white lines, from top to bottom.
Any input regarding this matter is much appreciated.
Thank you.
Current Build
CPU - Intel® Core™ i5-7500 Processor
Motherboard - MSI H110M Gaming Micro ATX LGA1151 Motherboard
RAM - Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
GPU - Zotac GeForce GTX 1070 8 GB MINI Video Card
Case - Segotep π Cube
Storage - Sandisk SSD PLUS 120GB 2.5" | Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive | Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
PSU -     Super Flower Leadex Silver 550 W 80+ Silver
Display(s) - 24" Class Full HD IPS Monitor (24MP68VQ-P)
Cooling - CRYORIG M9i | Cooler Master SickleFlow X 120mm Fan (Intake) | Cooler Master SickleFlow X 120mm Fan x2 (Exhaust)
Keyboard -  Corsair K70 RGB MK.2 Wired Gaming Keyboard
Mouse - Corsair M65 RGB ELITE Wired Optical Mouse
Sound - Edifier XM6PF
Operating System - Windows 10 Pro
PCPartPicker URL - https://pcpartpicker.com/list/3DhQkX
https://linustechtips.com/topic/702899-need-help/
I have a similar laptop, but no screen issue. looks like a controller issue.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/702899-need-help/#findComment-8984341
or a gpu issue.
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984349
3 minutes ago, KhaierKaizer said:
~snip~
definately sounds like the controller
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/702899-need-help/#findComment-8984350
Controller?..Is it fixable?
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984366
1 minute ago, Sierra Fox said:
So we can rule it out, what happens if you plug in an external monitor? does the same thing happen or is it isolated to the Laptop screen?
Oh, I forgot to mention this part. It is isolated to the laptop screen. I have tried plugging into external monitor, and it works just fine displaying in the external monitor.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984379
*sigh*
At least the LCD panel is okay.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984419
Isnt the controller a part of the main board?
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984494
I'm sorry, I'm not very familiar with the parts. Still new at this. To fix the controller issue, is to repair (or replace) the main board. Is this correct?
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984522
I recently opened up my mom's studio 1458 to fix cooling. the lcd ribbon was connected directly to the main board. that might be an expensive problem for you.
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984525
I guess so. like @Sierra Fox said. Due to old age, parts are getting harder to get.
*sigh*
After tinkering with the laptop a bit. I decided to put a new skin on it. xD
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984580
good looks don't fix hardware issue. but damn that is a nice skin. who can go wrong with carbon fiber
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984607
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984621
It soothes the broken soul:D.
Anyway, thank you for the replies and inputs.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984622
1 minute ago, MrMcMuffinJr said:
whoa
My wallet starts to shrink exponentially.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984631
that is probably the only solution, other than buying a new laptop. do you have a budget. if you plan to do so.
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984637
Well, I thought I can simply DIY-ed the repair. Buy some parts and repair it. Dell's laptop is easy to work on, easy to disassemble and reassemble. Everything is literally plug and play, with few screws aside.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984674
Okay, good luck
My Stuff n' Things
https://linustechtips.com/topic/702899-need-help/#findComment-8984679
5 minutes ago, MrMcMuffinJr said:
Okay, good luck
Thank You!
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-8984723
This is my solution. Buying external monitor is much cheaper than fixing/buy mainboard, though is not full HD whatnot. Still, I'm satisfied with this setup.
Next mod, probably eGPU setup:D.
Current Build
https://linustechtips.com/topic/702899-need-help/#findComment-9027270
