Hello community,
I just put together my PC and i realized that my case (Rosewill Thor V2) had a few wires stripped where the molex connector for the fan controller is supposed to be. Can anyone help me find a website where i can find 4 male molex connector pins (For Female Pins) and a 4 Pin Female Power Connector (For Male Pins). All information is appreciated.
-Thank You
https://linustechtips.com/topic/702632-i-need-help/
Welcome to the LTT forums.
Could you tell us your location? That would help finding some usefull sites where you can order your molex pins, connector and possibly a crimping tool.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/702632-i-need-help/#findComment-8981001
Just now, sam_fisher007 said:
Any electronics store should have some. Also, that looks like a fault. Maybe return the case if its not too much hassle.
Yea the thing is that i already put all of my parts into it and just thinking of taking it apart and storing it away somewhere for like a week waiting for the new case to come white all my parts collect dust somewhere just bothers me. Also, there are no electronic stores near me that sell the pins and such. I could buy it from primochill for like 70 cents but shipping is and extra 7 dollars which is stupid, so if there is any other alternative i will take it otherwise il just spend the $8.
https://linustechtips.com/topic/702632-i-need-help/#findComment-8981280
What about borrowing a molex connector from something like a molex to pcie power adapter if your card came with one or anoother unused molex connector.
The pins are really easy to take out with a thin screw driver, just 2 tabs push in on either side of the pin. Or you could solder on the wires.
https://linustechtips.com/topic/702632-i-need-help/#findComment-8981311
I'll see if i have any spares, sorry if i seem kinda cheap but i'm a high-school student that doesn't have that much money.
https://linustechtips.com/topic/702632-i-need-help/#findComment-8981327
