Hi!
I just upgraded my pc some week ago. From amd to intel.
I have an overclocked intel es cpu on 4.1 ghz.(its like an i7 6700k now).
GA-Z170-D3H , r9 280x, psu 650w. 12gb ddr4 crusial 2133mhz (I got 16gb but computer wont start with the 4rth stick, I think that its broken).
First of i had/have this problem. Overclocking is stable, when i restart computer its fine. But if i turn off the computer and leave it off for a while and then want to start it, i push the power button. Everything turns on, no screen because computer just dies like, like if you removed the power cord to the computer, 2 sec after i turn it on. The computer restarts by itself, turns on, no bios, dies after some sec, it does this 3-4 times before finally booting(starts and dies before bios), and then the overclock works too. Like cold boot or something. The first time the computer dies before bios, it shows code 19- pre memory South bridge initialization is started on the motherboard and quickly dies. I only click on the power button once too.
I tried downgrading bios and the problem didn't came so izi. But it came back today and i had an hard time to get it stable. I decided to upgrade bios to the latest, i mean what could be worse?. Flashed correct bios and it sayed bios update completed, restarting. After that it wont turn of. It starts for some seconds goes through the bios codes stays at code 18-Reserved dies and restarts show code 18 restarts again, and again in a endless boot.
I have tried to remove cmos battery for like half an hour. Tried to clear cmos on the motherboard pins, tried with 1 ram.
Same problem endless reboot code 18....
I have had it on 4.2 but i didn't got it stable.
Hope that you have time to read this :) .
Thx
https://linustechtips.com/topic/702523-help-with-es-6400t-cpu-mob-problems/
