I have had constant crashes for over 2 weeks. HELP. Tried to reinstal gpu driver. No good. memtest was fine. HELP
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/702323-help-with-constant-crashes/
try running some stress tests to see what part is being stressed when it crashes,could also try sfc /scannow
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
good enough?
Build
Most likely Bad RAM, but memtest was fine? so I dont know.
can also be some error with windows.
Say if you still get crashes after sfc /scannow
but can you show more information about one the errors (the ntoskrnl.exe)?
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
yeah i will sure but right now i am running the windows mem test in extended mode and it needs like 15 passes to be successful. and well the cache is on too.
Build
sorry for the late reply.
Build
I think you can also open that file it is mentioning (C:\WINDOWS\Minidump\xxxxxxxxxxxxx.dmp)
-Stephen Hawking
how do u open dmp?
Build
9 minutes ago, DeezNoNos said:
how do u open dmp?
I dont remember :(
But anyway, but almost all google results I found says the error is either a driver OR bad ram. (it might also be bad ram slots i think)
-Stephen Hawking
6 hours ago, Mihle said:
I dont remember :(
well how do i diagnose that :/
Build
1 hour ago, sam_fisher007 said:
Hi mate. Need more info...
Is this system new or old
Does it crash when idling or playing games?
Any overclocks?
Cheers
Hi
I assembled it in march
all the times it was idling
and just a gpu oc which is reset.
Build
3 minutes ago, DeezNoNos said:
Hi
Does sound like a windows thing, but windows sits on your ssd.
I'd do a test on the ssd. Not sure what tool you can use for m.2 drives.. try ubcd (ultimate boot cd). I would start there, if the ssd is fine, maybe create a new partition with 30gb and install windows there see if it crashes still.
mine is a 850 evo for magican works?
Build
