Hi all I just got a master case maker 5 in and I noticed the fan / led controller has 2 pin connections for the LED.
I was planning on ordering 2 or 3 Darkside Connect dim-able  UV strips to replace the stock red.
My problem is that all I see for the Darkside adapter cables seem to be 3 pin?
Some of them look like they are 2 pin but the pictures are so garbage I can't tell.
Does anyone know what adapter type i need? Sorry for being retarded I just don't want to waste time ordering the wrong things.
This is a link to the one i was going to get it.
http://www.performance-pcs.com/darkside-connect-dimmable-12-modular-led-strip-uv-rev4-balanced.html
Thanks guys
https://linustechtips.com/topic/701656-master-case-maker-5-led-question/
Thanks guys
They have different selections for connectors such as 2 pin to molex and others in between. If you are just wanting to lights to be on at full brightness using molex to the 2 pin will be the one you will want to select.
