I have a Thermaltake Core v1 case along with a GA-h170n-wifi motherboard. I turned on the system with the power button and it was able to boot. Then I tested out the reset switch on the case which did not work. I saw that i connected the front panel header on the wrong pin (one header was on the NC pin while the other was on the + pin for the reset switch). Then, I plugged the reset switch header into the correct position, and it still doesn't work in BIOS/UEFI. Can anyone explain to me if I damaged the headers/pins on the motherboard or the case?
Desktop:  Intel Core i5-6400 | Zalman CNPS9500AT CPU Cooler | EVGA GTX 1050 SC GAMING 2GB | 1x8GB DDR4 Corsair LPX | Gigabyte H170N-WIFI | Intel 600p 256GB SSD | Seagate Firecuda 1TB SSHDCorsair CX450M (Gray Version) PSU | Thermaltake Core V1 Mini-ITX Case |
https://linustechtips.com/topic/701522-reset-switch-doesnt-work/
My front panel looks like this:
Image result for motherboard front panel header however in the motherboard manual pin 9 is called "NC (no connection)," which is what I connected to with the reset switch (again, reset switch was plugged into pin 7 and pin 9 in the diagram). Also as a side note I tested the reset switch in the BIOS/UEFI.
My specs:
intel core i5-6400 cpu
gigabyte ga-h170n-wifi motherboard
corsair 1x 8gb DDR4 vengeance lpx @2133mghz RAM
zalman cnps9500at cpu cooler
corsair cx450m psu
thermaltake core v1 mini-itx case
no OS as of yet
https://linustechtips.com/topic/701522-reset-switch-doesnt-work/#findComment-8968349
