Power help (ASAP)
Solved by suchamoneypit,
if the 24 pin is slotted in, its fine. My clip actually broke off completely.
The CPU cable should definetly reach, although maybe not in the best looking path. The shortest path is literally like 1 foot away if you go over the motherboard.
And its legoes man, seriously. Its not hard at all. Square plug ONLY plugs into a square socket for example. You can't mess it up. When it comes to the tiny plugs from your case labeled "PWR" or "HDD LED", you literally plug in onto the pins that are labeled the exact name on the motherboard. It can't get any simpler than it is.
