Will my PSU be enough?
Go to solution Solved by BrinkGG,
1 minute ago, XyzWoot said:
I was wondering if my thermaltake lightpower 600w black edition be enough for a Gigabyte GTX 1060 Xtreme Gaming 6G? thanks! :D
Yep! As long as I'm looking at the right one.
 https://www.google.com/search?q=thermaltake+litepower+600w&safe=strict&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiYwv_moNTQAhVqiFQKHea-DKIQ_AUICSgC&biw=1446&bih=1450#imgrc=ETUx11UZLrNaSM%3A
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958622
More than enough. It's a OK-to-bad-ish [Tier 6 :/] PSU with 600W. What else is in that rig?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958632
3 minutes ago, Brink2Three said:
Yes it is! :D thanks! :D
Yay! thanks! Yup sadly :( that is why i was wondering because it's not a good PSU T_T
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958648
1 minute ago, Comic_Sans_MS said:
No. Thermal Take Lite power is shit and should be replaced.
The FSP models might be okay-ish, but not for a computer GPU, I wouldn't touch the other ones, not 80plus certified and calling a 500W a 600W, GTFO!
First off, calm down.
Second of all, It's fine. The PSU isn't rated well, but if he already has it and knows it works then its fine. Yes its incorrecly rated, but that's why you check the 12v rail rating. (And depending on the model, its either 480w or 540w. Soooo....)
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958666
the litepowers have 4 OEMs, fsp, cwt, HEC and solytech(deer) IIRC, and solytech is known to make junk so i'd avoid them even if one of the OEMs are fine.
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958718
Sorry, no.
Single 12V rail = Likely Bad.
12V rail output =/= Good.
All 3 "600W" TT Litepower are made by average or bad OEMs (HEC and Solytech). (The products manager at Corsair said  "Divert your eyes." when people where asking if HEC (the better of the 2 OEMs) was the OEM for the new VS line and, he also stated that he had nothing to do with that, it was the previous products manager and he dislikes HEC's production facilities)
(Delta made some of the low wattage Lite Power back in the day)
https://linustechtips.com/topic/700583-will-my-psu-be-enough/#findComment-8958743
