Will my Seasonic X-460FL be ok to run 10 hard drives in a Media PC?
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/700574-psu-load/
20 minutes ago, VerticalDiscussions said:
Well, yeah it should. Are they high performance drives tough, like Western Digital Raptors?
No, just standard 3-4TB 7200rpm WD/Seagate
https://linustechtips.com/topic/700574-psu-load/#findComment-8958631
I mean, if you're powering just those drives and like an AMD A10 then it's a little overkill but it's fine, what you plan on doing.
https://linustechtips.com/topic/700574-psu-load/#findComment-8959869
23 hours ago, VerticalDiscussions said:
They should consume about 9-12 watt at max load each, so as long as the remainder of the parts are relatively efficient, you should be totally fine :p.
It is powering my whole system with an Ivy bridge i3, Radeon 5450, a fan controller and a SATA controller card.
https://linustechtips.com/topic/700574-psu-load/#findComment-8963897
You're fine.
https://linustechtips.com/topic/700574-psu-load/#findComment-8967605
