Green sends the power on signal to the supply, black is ground.
https://linustechtips.com/topic/70044-ax750-water-cooling-loop/#findComment-959888
Okay now can you tell me which is the first pin like the end closest to the snap thingy or the opposite end
The pin labeled 1. (3.3V)
https://linustechtips.com/topic/70044-ax750-water-cooling-loop/#findComment-959901
You short the system to power it on by connecting the green wire to any black one (usually you use the one next to it) you an use a piece of wire or a paperclip, yes before you ask it is safe. When you want to turn the pump off pull the wire out. Make sure your CPU power cable and GPU power cables are disconnected before you short the 24 pin.
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/70044-ax750-water-cooling-loop/#findComment-959902
