Hey guys!
So, yesterday I got my PC Parts from Newegg (Hooray!) and I got straight into upgrading my prebuilt HP Pavilion 500-164. I bought a GTX 1050, a Power Supply upgrade from a 300W generic PSU to 430W from EVGA, a new case, and a CPU cooler which I never ended up using due to its huge size (Hyper 212 EVO looks way bigger in person-- and taller too!).
Anyway, I finished putting all the wires in making sure I didn't miss anything, and put everything in. The PC posted and booted up fine, but one small issue popped up again: my WiFi doesn't detect anymore. I try to find signals but my network shows nothing, and the troubleshooter says I should set some old networks as default. When I opened Device Manager, and looked at the network drivers. For some reason, there were many drivers called "Wan Miniport" or whatever? (I'm assuming the other 2 were just normal Qualcomm Atheros drivers). None of my drivers have a yellow triangle so far, and yet the WiFi still doesn't work! Any help? I use this computer fairly heavily towards networks for school, so I want to fix this ASAP! Thank you in advance for all the help you provide!
https://linustechtips.com/topic/700349-integrated-network-driver-help/
24 minutes ago, ItalianBreadP said:
Hey guys!
The "driver" is just software.  Regardless, just remove all of your known networks and reconnect back to the one you want.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
17 minutes ago, ItalianBreadP said:
But the problem is I can't find any networks at all
Correct, you you don't have the drivers for the device, so you will have no ability to utilize the features of said device (The wifi card).
You will need to install the drivers
They will likely be on the disk that came with the motherboard, if you can get internet another way, they should also be on the motherboards website. You probably already know but wired connections are far superior to wireless.
Computers r fun
Yeah, I'll have to check MSI's website because I definitely don't have the disk for an MS-7778 ver 1.0 mobo. I can't have Ethernet because the actual modem is downstairs. Does Ethernet work through the Ethernet outlets you find in every room or are those just for phones?
Oh yeah, and sorry if I'm late on this, but this is a prebuilt that I've used before, so the driver should already be installed, right?
them just add the network back.
Ethernet is a protocol that uses Cat5e cables. If cat5e cable is wired throughout your building, and one side is connected to the router, then connecting your computer to it will be plugging it into the router. Wired connections are more reliable, and faster.
Computers r fun
Ah, okay. Awesome! I'll grab an Ethernet cable from my dad's office and give it a go. Thanks!
