CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($191.91 @ Jet)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  ($45.98 @ Newegg)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($80.99 @ Newegg)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($39.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: PNY GeForce GTX 1060 6GB 6GB Video Card  ($246.39 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($62.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($53.49 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.68 @ My Choice Software)
Monitor: Asus VP239H-P 23.0" 1920x1080 60Hz Monitor  ($99.95 @ B&H)
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse  ($28.99 @ SuperBiiz)
Total: $985.25
Generated by PCPartPicker 2016-11-29 17:03 EST-0500
https://linustechtips.com/topic/699454-my-first-build/#findComment-8945925
Total: $985.25
this is all good, but would use kinguin to get os
MF UH BEANS
https://linustechtips.com/topic/699454-my-first-build/#findComment-8945947
Just now, Gwish said:
Not anything extreme, as long as the game plays well on it and it isn't too expensive I'd be happy.
Well there are a lot of monitors to choose from if that's your case. I would recommend a monitor that is 1920x1080 or at least anything above the resolution of 720p because 720 isn't exactly the best quality. Any monitor would do really.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/699454-my-first-build/#findComment-8945956
@deXxterlab97
So this can be built :P
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  ($60.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($26.00) Kinguin
Total: $993.53
Generated by PCPartPicker 2016-11-29 17:16 EST-0500
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/699454-my-first-build/#findComment-8945990
1 minute ago, Mr.Meerkat said:
@deXxterlab97
Total: $993.53
wow dis is gooderer
MF UH BEANS
https://linustechtips.com/topic/699454-my-first-build/#findComment-8946000
1 minute ago, deXxterlab97 said:
There is a chance
Fair enough :P (by they way, windows 7 keys can still be used for activating windows 10 so you know...)
https://linustechtips.com/topic/699454-my-first-build/#findComment-8946012
3 minutes ago, deXxterlab97 said:
I am not a disabled person
No, as in putting your windows 7 key in and it activates your windows 10 without having to do the cheaty disabled person thing :P
https://linustechtips.com/topic/699454-my-first-build/#findComment-8946039
No I mean the free activation ends and you can still activate it with some sort of assistive stuff
Nope, I did it 2 weeks ago, entered my windows 7 key when prompted like it does normally, activated like normal without the assistive stuff
https://linustechtips.com/topic/699454-my-first-build/#findComment-8946049
get OS from reddit for $20-30.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($45.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory  ($76.99 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($60.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($34.99 @ Amazon) get later if you can't handle rebates.
Video Card: XFX Radeon R9 Fury X 4GB Video Card  ($304.98 @ Newegg)
Case: Deepcool DUKASE WHV2 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($44.99 @ Newegg)
Monitor: Asus VC239H 23.0" 1920x1080 60Hz Monitor  ($89.99 @ Newegg)
Total: $977.88
Generated by PCPartPicker 2016-11-29 19:58 EST-0500
https://linustechtips.com/topic/699454-my-first-build/#findComment-8946826
