2 minutes ago, Dawson Wehage said:
better off going with a GTX 1060 6GB or 1070
Are you okay? (for the second time I'm pretty sure)
A 390 is almost (only put it in bold as you'll miss it) as fast as a 1060 thus that's not upgrading, that's sidegrading :P
1 minute ago, NathyLock said:
Is the RX 480 any good? haven't looked much into it.
If you're upgrading, minimum is a fury/980ti/1070 as a 390 is just as fast as a RX480 with the 390 being almost as fast as a 980...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/699362-rx-490-info/#findComment-8944918
i'm fine thank you very much, and you?
lttstore.com
https://linustechtips.com/topic/699362-rx-490-info/#findComment-8944924
I'm fine :)
It's just that sometimes you post things that are slightly dodgy :P
https://linustechtips.com/topic/699362-rx-490-info/#findComment-8944943
12 minutes ago, NathyLock said:
Thinking about upgrading my R9 390. Do any of you guys know when the RX 490 will come out and how it will perform? Thank you
We don't really know anything about the 490 yet.
If you want to upgrade now, the only viable options are the 980Ti or 1070 at minimum. The 1060 and RX 480 aren't that much faster than a 390 to make the upgrade worthwhile. We're expecting to hear more about the 490, hopefully early 2017, so if you can wait, then wait. ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/699362-rx-490-info/#findComment-8945115
