Hello,
I'd like to know if my temps are OK. Under load playing LoL at 60FPS locked at highest setting at 1080p the CPU is around 96F and GPU 99F. While playing CS:GO at 75FPS locked highest settings at 1080p, the CPU gets to 98F and the GPU to 98-99F. Here are my specs:
CPU: Intel i7 6700K
GPU: GeForce GTX 970
PSU: Corsair CX750W
MOBO: Asus Z170-A
RAM: 16GB of DDR4 at 2133MHz
CPU Cooler: NZXT x61
https://linustechtips.com/topic/699360-are-my-temps-ok/
3 minutes ago, rf9661 said:
Hello,
CPU: Intel i7 6700K
PSU: Corsair CX750W
MOBO: Asus Z170-A
In Celsius?
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8944855
4 minutes ago, rf9661 said:
Hello,
CPU: Intel i7 6700K
PSU: Corsair CX750W
MOBO: Asus Z170-A
35-37 Holy shit man. What kind of freezer are you using?
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8944873
Hello,
CPU: Intel i7 6700K
PSU: Corsair CX750W
MOBO: Asus Z170-A
IF those are Fahrenheit, you are doing amazing. If those are Celsius, you practically created a portal to hell.
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8944881
4 minutes ago, Beeeyeee said:
give me in Celcius
1 minute ago, Alaa said:
35-37
Unfortunately... LMGTY is banned.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8944921
4 hours ago, Eazy Cheezy said:
That's amazingly, fantastically, ridiculously freakin' low temperatures! What is it being cooled with? Liquid nitrogen mixed with the soul of a Yeti?!
Living in Canada would be easier.
My System:
My Phone:
My Watch:
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8946693
5 hours ago, Beeeyeee said:
what the heck kind of coolers are you using?? what kind of program are you monitoring this with?
Simply a NZXT Kraken x61... Lordy, I didn't think the temps were THAT good! I'm using CAM to measure temps.
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8946745
Either CAM is showing you wrong temps or your fans are running on 100% and your room temps are about 5C
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8949155
Play easy games at locked frames at low res would yield less usage. Temps seems about right. I get the same temps on my main rig loop.
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8949618
yes, on waterloop. not on GPU on air. The temps are suspiciously low
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8950027
Well I'll call bs then.
https://linustechtips.com/topic/699360-are-my-temps-ok/#findComment-8950238
