Hey Guys,
I'm just trying to get your thoughts/ideas/discussion about PC desks that house your components.  You have probably seen these by Lian Li or the Cross Desk by Red Harbinger (if not I threw some links below), but these are very expensive.  Lian Li's cheapest is around $800.00 U.S. and the Cross Desk is about $1700.00 U.S.  I would like to see a clean looking pc desk that houses all that I could afford at a much cheaper price range around $150.00 to $300.00 and still had RGB lighting and what not.
 http://www.lian-li.com/en/products-computer-desk/#all/1/grid
http://www.redharbinger.com/shop/cases/cross-desk-usa-only/
So my questions are...
Would you want a PC Desk?
How much would you spend for a desk/PC case combo?
What would you expect it to do or include?
Thoughts???
https://linustechtips.com/topic/699317-pc-desk-chassis/
This is actually a project I am working on right now- manufacturing both a high and low end of desk case. I will keep you posted on progress! And any thoughts from people on here with regards to what they would expect to see would be of great help as I am still in design stage.
https://linustechtips.com/topic/699317-pc-desk-chassis/#findComment-8944325
1 hour ago, NinJake said:
I'd say you'd be crazy to spend that much for a desk that houses a PC. You could try to spend the 150-300 on materials from home depot (or a similar store) and build your own.
that was my thoughts exactly.  For the price you would pay for their desks you could by GTX 1080 and have a handful of cash left over.  I'm rather asking if you would be interest in a desk case instead of the traditional case and what would you pay for it?
https://linustechtips.com/topic/699317-pc-desk-chassis/#findComment-8944624
The only benefit to a desk case would be to save space, if I had limited space to place an actual case (mid or full tower) then no, I wouldn't buy a pre-built desk-case. I would much rather put in the time and effort to build my own desk that suited the needs of whatever room it would be placed in.
https://linustechtips.com/topic/699317-pc-desk-chassis/#findComment-8944823
