Hi ! I just want to know if a SeaSonic X Series X-850 will be enough to power my rig as I'm thinking of getting a 290 in crossfire for my rig . Other recommendations for GPU are welcomed too ~!
My Current Rig :
i7-4790k Overclocked to 4.7Ghz at 1.325V
GA-Z97X-Gaming 7 Motherboard
H100i AIO cooler
16GB of DDR3 1600 Corsair Vengeance Memory
Deepcool 350 RGB Lights (Thinking to change to a NZXT Hue+)
250GB SSD and 500GB HDD
CPU- Intel i7-4790K @ 4.68GHz GPU- - RAM- 16GB DDR3 1600 Corsair Vengeance  SSD- Crucial MX300 275GB HDD- 500GB 7200RPM Case- Phanteks ENTHOO PRO M ACRYLIC Motherboard - Gigabyte GA-Z97X-Gaming 7 OS- Windows 10 Mouse- Logitech G502 Keyboard- Razer BlackWidow Chroma
https://linustechtips.com/topic/699296-graphics-card-and-psu/
that psu would be solid
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944007
My Current Rig :
H100i AIO cooler
It'll power fine.
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944051
2 hours ago, Soundsystem90 said:
290 crossfire is a bad decision, go for a single 1070.
Hmm.. 2x R9 290 in crossfire will cost me around SGD$460(est $230 each) while the GTX1070 will be around SGD$600 ,all cards with 3 fans gigabyte version
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944731
Two things:
- a single, more powerful, graphics card is always better than any CF or SLI set up. Not all games support multiple graphics cards and there's often glitches, etc.
- a single GTX-1070 can run on a basic 500watt power supply. So you need to compare the price of 2x 290s + 850watts to 1x 1070 + 500watts.
- er, third thing - Two 290s will dissipate much more heat and consume more power and be much noisier. You might therefore, also need to spend extra on cooling fans for the case, to get rid of the extra heat.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944784
4 minutes ago, Quaker said:
Two things:
Yeah i know about the first point ,but i have already ordered my 850w psu ,so the price of the psu won't affect
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944814
That PSU would be more than enough but dual 290s would be very hot...
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/699296-graphics-card-and-psu/#findComment-8944862
