My black friday build is coming within the next week, and I do quite a bit of video editing. My case, however, is an S340, which afaik doesn't have any expansion bays, and either way I really wouldn't like to put anything in expansions bays because they look ugly imo. So, I need an external solution that can house an SD card (and micro sd card would be nice, but not needed). I don't want it to stick out of the computer, but actually be a cable with the hub on the end of it. Nothing too expensive, but its sure to last and can handle SD cards at high speed. Interface doesn't matter, USB 3, 3.1 type a, type c, whatever. Thanks
Intel i5-6600k (Cooled by a 212 evo) - Asus Z170-A - Asus Dual OC GTX 1060 - NZXT S340 - WD 1TB (Getting SSD this month, hopefully) - 8GB DDR4-2400
LG G4 - Asus Zenwatch 2
https://linustechtips.com/topic/698364-need-a-sd-card-hub/
I personally like this one from Kingston, this being a newer version in white and black:
https://www.amazon.com/Kingston-Digital-Hi-Speed-Reader-FCR-HS4/dp/B00VAGX6MW/ref=sr_1_3?ie=UTF8&qid=1480300919&sr=8-3
https://linustechtips.com/topic/698364-need-a-sd-card-hub/#findComment-8935032
Oh nice, thanks! This is exactly what I was looking, and the fact that it's in white is even nicer
https://linustechtips.com/topic/698364-need-a-sd-card-hub/#findComment-8935651
