CPU front Bus issues?
Solved by SkilledRebuilds,
Back in the day before XMP set profiles. (Some motherboards do not lock the frequency and XMP sometimes does this too)
You had to manually set them to 1333/1600/1866/2133 and so on..
But.. when overclocking the FSB, the Memory speeds would rise with it.
Setting Stock 1600, and overclocking the CPU via FSB, the ram would rise ABOVE its Rated 1600mhz Speed,
once pushed too far with no extra voltage (likely with overclocking FSB) they will cause BSOD/General Instability when Under load in an Overclocked System.
1600mhz ram would be taken to unstable levels, hence you get told to run @ 1333mhz, and with your overclock, it would be pushed faster accordingly and be stable sitting under its rated speed, yet faster than 1333mhz.
