3 minutes ago, MrHarv said:
Have you plugged the Monitor cable like DVI/HDMI/DPI into the 1060? If no and plugged it in the motherboard port then it will say Intel Graphics. Plug it in your graphics card ports so that is picks up visual from the GPU.
Ok let me try that
https://linustechtips.com/topic/697246-help/#findComment-8924505
I tried that but when I do that the monitor doesn't turn on
https://linustechtips.com/topic/697246-help/#findComment-8924511
