Be Quiet Dark Pro 3
2 minutes ago, prostrike33 said:
I've seen some reviews of this cooler (Be Quiet Dark Pro 3), but just wanted to know how it stacks up to the noctua nh-u14s as they are about the same price right now. (be quiet is about 10 bucks cheaper)
BeQuiet is beefier so I'd get that, plus its cheaper. Good luck w/ the shitty wrench though
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/697224-be-quiet-dark-pro-3/#findComment-8924358
4 minutes ago, prostrike33 said:
Yeah. That seems to be a common negative from all the reviews I've seen.
Thanks
MAKE SURE YOU HAVE LOW PROFILE RAM PLS
https://linustechtips.com/topic/697224-be-quiet-dark-pro-3/#findComment-8924370
Just revving this a bit, the wrench is not a problem unless installing on 2011 platform, you use it to only to mount nuts to the cooler itself and then secure it by screwing it from behind
I got the dark rock 3 and iirc they all have same mounting kit, it was easy after i lined and started the first screw from back
https://linustechtips.com/topic/697224-be-quiet-dark-pro-3/#findComment-8937777
