i bought some cheap converters from china which work for charging the device but does not synchronize. the converters i have a 30 pin to 8 pin, micro usb to 30 pin and a micro usb to 8 pin. i bought a cable with 8 pin on it made by insignia which works. i reset my ipod touch and now its asking for the cable to be plugged in for itunes. i do have an itunes account but my converters do not recognize or sync. i fucked up with the purchase because the ipod touch is the same size as my 5" mobile phone so i will have to see what watching the video is like. it still may be a good purchase at $10.
https://linustechtips.com/topic/697163-lightning-cable/
those wires from china are shit. I had a 30pin apple charger to a 3.5mm jack and it didnt play music. IT IS RUBBISH. buy quality items pls
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/697163-lightning-cable/#findComment-8923795
they charge just fine, thats all they do. from my googling just now they do not have the microchip in them i can only assume right but i thought them china men figured it out. if i buy a china 8 pin to 30 pin will it work on my insignia 8 pin usb cable i bought for $20 from bestbuy
https://linustechtips.com/topic/697163-lightning-cable/#findComment-8923804
oh then idk. the one i got from amazon couldnt play music so now i despise it
https://linustechtips.com/topic/697163-lightning-cable/#findComment-8923812
