Hey!
I'm building a gaming pc soon, and its going to be white with magenta OR blue accents
My case (NZXT S340 white) and GPU (Asus 1060 6GB dual) are both white, and I don't know what other components to make the main color or the accent.
Heres my build https://pcpartpicker.com/list/chQn8K what do you guys think I should make white or blue/magenta
Also will the black mobo look decent w/ the white case? I might get a white mobo but I think only higher-tiered mobo's have white PCB's
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/697095-help-with-build-colors/
10 minutes ago, QuantumBit said:
Hey!
:D the fun and REAL questions (people need to ask these more).
Part list incoming Whats your budget?
Edited by Made In Canada
Words
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923247
$800 no peripherals/office-windows
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923255
I just got rid of peripherals and office-windows. It somehow lowered to $700??? Let me check some stuff
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923261
Budget is 700-800. I already bought the case and GPU
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923266
14 minutes ago, QuantumBit said:
Hey!
The motherboard is mATX and only has 2 memory slots. You should consider investing more to get an ATX motherboard so that it will not look lost in the S340. Four memory slots with a 2x4GB memory kit would also be better.
The S340 in the build is black.  NZXT S340 (White) ATX Mid Tower Case  is the white version. Note the white case interior is black but the fans have white blades.
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923277
The mobo I have has 4 ram slots..?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923280
2 minutes ago, brob said:
Yes. But is is mATX.
This is my first build do 4 mATX slots = 2 actual ones?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923311
But ATX boards are like $100
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923338
Not necessarily. Most modern gaming GPU are double width, so they do occupy 2 slots on the motherboard. But most other expansion cards are single width and only occupy one slot.
The mATX motherboard in the OP has three PCIe slots. One x16 (typically) for a gpu. The other two are x1. However, a double width gpu will cover one of the x1 slots.
Yes, ATX motherboards are more expensive.
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923347
34 minutes ago, QuantumBit said:
Hey!
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ NCIX US)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($49.99 @ Newegg)
CPU Cooler: Deepcool CAPTAIN 240EX WHITE 153.0 CFM Liquid CPU Cooler  ($95.99 @ SuperBiiz)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($119.99 @ B&H)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  ($89.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($79.99 @ B&H)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($63.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.58 @ OutletPC)
Total: $805.50
Generated by PCPartPicker 2016-11-25 20:40 EST-0500
READ: This list is a black and white one (which i recommend since its not only easier to match, but looks much more cleaner) and has a few parts you can switch. The list has two CPU Coolers to choose from, and the CPU can be swapped out for a i3-6100 which would run great (the key to the i3-6100 is fast ram, which i have on the list).
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923350
Sorry I'm new and I don't understand anything you're saying. I thought we were talking about the ram memory slots?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923360
No, the PCIe (expansion) slots. The motherboard in the OP has four memory slots.
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923367
44 minutes ago, QuantumBit said:
Hey!
CPU Cooler: RAIJINTEK TRITON BLUE 100.5 CFM Sleeve Bearing Liquid CPU Cooler  ($89.99 @ Newegg Marketplace)
Motherboard: Gigabyte GA-Z170X-UD3 Ultra ATX LGA1151 Motherboard  ($172.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($99.99 @ NCIX US)
Total: $823.51
Generated by PCPartPicker 2016-11-25 20:50 EST-0500
This is the blue and white one.
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923368
Total: $805.50
I meant 700-800 with the gpu
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923369
with the gpu and case? or just gpu? (you said you already bought those so im asking now).
words
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923376
with case and gpu, I'm just saying that I already bought it so please don't change it
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923381
oh, ok.
Also, what games do you plan to play (it will change the CPU i put in the list as it will save money for the color scheme, and remember this, THE I3-6100 IS A GOOD CPU).
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923391
oh, ok.
Cities skylines and space engineers
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923395
can you bring up the price at all? i mean, i could build the list for the price, but the parts will not match (unless you like only black). the current price for the lowest while keeping looks and performance the build can go for matching colors is $950 before rebates (but rebates dont ever seem to work in the end).
Words
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923441
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($104.88 @ OutletPC)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler  ($38.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($119.99 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3200 Memory  ($62.99 @ Newegg)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($229.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($56.99 @ Newegg)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM  140mm Fan  ($17.88 @ OutletPC)
Total: $861.15
Generated by PCPartPicker 2016-11-25 21:07 EST-0500
The CPU cooler would have on of the two fans i added (with the white rim) on, to keep it looking sharp.
-Made In Canada
https://linustechtips.com/topic/697095-help-with-build-colors/#findComment-8923465
