Hi I'm from NZ
1. Budget & Location
$2500 NZD in New Zealand
2. Aim
Playing games occasionally, browsing, using Visual Studio for programming and other general computing
3. Monitors
I plan on purchasing a 1440P monitor that is IPS
4. Peripherals
No need for peripherals
5. Why are you upgrading?
Because I have always wanted to build a computer and I only have a laptop at the moment.
This is my current parts list:
https://nz.pcpartpicker.com/list/n6Qd9W
https://linustechtips.com/topic/696373-need-help-with-first-rig/
Nice good choice on the board. Its from the same family as my B150M from asrock which allows non k CPU overclocking! Atleast I think that one does :) check out the b150m pro4/hyper which is available in NZ its same price as some of the h110 boards if you wanted to save money
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/696373-need-help-with-first-rig/#findComment-8917473
https://nz.pcpartpicker.com/list/nRrBhq
id build somthing like this instead but that's my choice of case which I perfer over the next one. I added an nvme drive and got slightly cheaper ram which looks better and will match the build better. Added a better cooler too and went with rmi psu as it looks sweet with that case if you don't add the psu cover on the bottom on the 400c. But yea that's just what I'd do
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/696373-need-help-with-first-rig/#findComment-8917529
Hmmm. Thanks for the suggestions.
https://linustechtips.com/topic/696373-need-help-with-first-rig/#findComment-8917531
This is better.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($339.57 @ PC Force)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($63.00 @ 1stWave Technologies)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($251.23 @ PC Force)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($139.00 @ DTC Systems)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($205.85 @ PB Technologies)
Video Card: Sapphire Radeon RX 480 8GB NITRO+ OC Video Card  ($436.50 @ PC Force)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($149.00 @ DTC Systems)
Power Supply: Corsair RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($175.00 @ 1stWave Technologies)
Monitor: Asus MX27AQ 27.0" 60Hz Monitor  ($753.48 @ Aquila Technology)
Total: $2512.63
Generated by PCPartPicker 2016-11-27 06:38 NZDT+1300
https://linustechtips.com/topic/696373-need-help-with-first-rig/#findComment-8926293
On 27/11/2016 at 6:38 AM, lee32uk said:
This is better.
Total: $2512.63
Is that CPU cooler really a good choice? Some people I know that have had it complained about how loud it got.
https://linustechtips.com/topic/696373-need-help-with-first-rig/#findComment-8933509
