I'm looking a good 200 mm fan for my 600 T. I bought a crappy aero-cool one because it was red with red LED's in it.
I was looking at the cooler master 200 mm megaflow fans.
​any suggestions?
Amd Fx8150, Crosshair V Formula,  2X4gb Corsair Vengeance 1866mhz Memory, Msi 7950 twin frozr in Crossfire, OCZ Vertex 4 128gb ssd, 2tb WD Green, Corsair H100, Corsair 600T Chassis.
https://linustechtips.com/topic/6963-200-mm-case-fan/
I'ill look it up tanks but will the 230 mm fit in a 600t ? so far I know I need a 200mm
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-74602
Witch of the 2 has better airflow. I like the look of the Bitfenix but don"t want to fall into the same trap as with the aero-cool
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-74609
The Spectre Pro has 148.72 CFM ±10% and the Megaflow has 110 CFM. So the Spectre Pros have better airflow than the Megaflow.
Megaflow: http://www.coolermaster-usa.com/product.php?product_id=2947
Spectre Pro: http://www.bitfenix.com/global/en/products/accessories/spectre-pro#specs
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-74982
27.5 dBA vs 19 for the Megaflow. 8.5 dBA for 20-40 CFM
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-75087
Think the specters are the better ones... the extra noise wont bother me so much. I have a H100 with stock fans and that already sounds like an aeroplane taking off.
OH and I moved my cages near to the power supply so there nothing blocking the fan. I want a good Intake fan because I have the H100 extracting and the back 120 mm fan and my case is building up a lot of dust so now I'm trying to create a positive air flow.
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-75226
Well they will fit in regards to thickness & width (if mounted the right way), but the 230mm Spectre Pros have more mounting points than the 200mm which makes them taller (see pics on the Bitfenix website). I had to shave down the outside frame to fit it as an intake in my case (Corsair 650D), so you'll probably have to do the same if you go that route.
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-75368
can i use the same mounting points and how much do I have to shave off?
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-75401
Oh so its not that big of a mod to make 230 mm fit but i have never modded my case to make something fit... think to be save i'm going to get the 200 mm spectre pros
i cant buy from newegg I live is South Africa but i know of an online store here who does supply them.
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-75846
I actually didn't mod my case, just shaved a bit off the frame of the fan. But yeah, the 200mm will still work fine.
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-76033
oh I thought you ment you had to mod your case to make it fit...
But thanks for all your help. im going to make my order this weekend
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-78297
I would go for the Cooler Master MegaFlow 200MM Fans.
Moves a lot of air - 110CFM as compared to NZXT 200mm (which moves less air)
Inc it's rated for 19dB,
CPU: Intel i7 4790k Motherboard: ASUS Maximus VII Formula RAM: Corsair Vengeance Pro 32GB 2400MHz: GPU: 2x EVGA GTX 780 Ti's with ACX cooling PSU: Corsair AX1200 Watt Gold SSD: SanDisk Extreme 120GB SSD (Operating System) SSD: Mushkin Chronos 240GB (Games) Sound card: Creative Sound Blaster ZxR HDD: Seagate 3TB External OS: Microsoft Windows 8.1 Mouse: Logitech G502 Gaming mouse Keyboard: Corsair Vengeance K60 MX Red switches Monitor: ASUS VG248QE 144Hz
https://linustechtips.com/topic/6963-200-mm-case-fan/#findComment-78303
