overclocking your memory helps a lot on apu's the higher the speed the better
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
yes, its at the higest frequency i managed to get: 2133mhz, but im probably gonna put a dedicated gpu in(if i dont buy a dirtbike first)
ok. have you tried overclocking the gpu part of the apu as well?
Rig Specs:
Just now, Norwegian pc dude said:
i have messed around in the bios but i havent managed to do that yet. i have a asus a68hm-plus
ok. you can normally get 10-15% more out of the graphics bit
Rig Specs:
1 hour ago, Norwegian pc dude said:
jumper, cheked out your profile and fuck, you have alot of gpus. how do you afford all that
erm. i havent updated that in a while i have about 55atm :P
Rig Specs:
