So i'm new to building PC and I was wondering if someone can rate my pc if it is a good budget one and an estimated FPS, i'm mainly trying to play league on the PC but also battlefield.
https://pcpartpicker.com/list/CsjQf8
Does anyone think I should change the graphics card? Also my budget is $1k-$1.3k
https://linustechtips.com/topic/696085-help-on-build/
That gpu is not a good choice. Go with a 1070 if you have the budget or a 1060/rx480. I would get a cryorig h7 or 212 evo instead of an aio. Get windows for cheap on g2a or kinguin.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/696085-help-on-build/#findComment-8915237
What windows should i get pro or home and also can you link me to a 1070 you would recommend
https://linustechtips.com/topic/696085-help-on-build/#findComment-8926883
2 minutes ago, Tran said:
What windows should i get pro or home and also can you link me to a 1070 you would recommend, is this a good rx480 https://www.amazon.com/MSI-GAMING-RX-480-8G/dp/B01K1JTT8S/ref=pd_lpo_147_bs_t_2?_encoding=UTF8&psc=1&refRID=6PF9E2HBZRKSA706M3Q6
https://linustechtips.com/topic/696085-help-on-build/#findComment-8926904
30 minutes ago, Tran said:
Can you link me to one that you would recommend
Would usually recommend EVGA but they need some time to fix their cooling problem so might as well go with the 1070 that matches your motherboard,
https://pcpartpicker.com/product/YpH48d/gigabyte-geforce-gtx-1070-8gb-g1-gaming-video-card-gv-n1070g1-gaming-8gd
https://linustechtips.com/topic/696085-help-on-build/#findComment-8927089
You aren't going to use any of the things that come with pro. Home is good enough for almost anything you are gonna want to do. The brand of the 1070 doesn't really matter that much. I wouldn't get evga though because they had thermal pad issues. Here's a good one. https://pcpartpicker.com/product/fKp323/msi-geforce-gtx-1070-8gb-video-card-gtx-1070-gaming-x-8g
https://linustechtips.com/topic/696085-help-on-build/#findComment-8928103
