Hello Everybody. I've had my CPU and GPU watercooled for around 6 months now, no problems at all. But in the last couple of days my CPU Temp has been shooting up to around 70C not under load. MY GPU temp is normal though, and the water temp is around what it usually is too. What could it be? A bubble in the CPU block? How do I fix it?
https://linustechtips.com/topic/695921-cpu-heat-problem/
tip the case
around to force out any bubbles
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/695921-cpu-heat-problem/#findComment-8913512
May I just ask what CPU are your using, what voltages and overclock (if any). And what temps you get :)
Sorry for spying on your temps lol
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/695921-cpu-heat-problem/#findComment-8913633
