As long as everything ships internationally then I don't see a problem.  Though I would get the power supply from Amazon UK because if you got it from the US it would have a US plug.  Though you might have to pay customs?  I don't know much about that but I would research it before you buy just in case.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/694816-first-pc-build/#findComment-8903525
11 minutes ago, TurkeyClub said:
Does shipping negate the benefits?
Thanks and yes I will save that much with shipping included
https://linustechtips.com/topic/694816-first-pc-build/#findComment-8903595
If customs isn't a problem (I doubt it will be) then hell yeah save dat money.  ORRR put it into a better part like the next GPU up or more ram or a bigger SSD or something like that if you can.
https://linustechtips.com/topic/694816-first-pc-build/#findComment-8903605
Yeah thanks getting 1080 and waiting till Friday for them sweet deals
https://linustechtips.com/topic/694816-first-pc-build/#findComment-8903688
Enjoy! :D
https://linustechtips.com/topic/694816-first-pc-build/#findComment-8903713
