30 minutes ago, SirBatsy said:
Im been trying to find a dual vesa mount for my x34 and asus 4k monitor but cant find any
Any Help?
Thanks
This is a mount that has good reviews that supports up to two 27" monitors with 75 or 100mm vesa mounts.
It has really good reviews to.
https://linustechtips.com/topic/694288-vesa-mount/#findComment-8898270
1 hour ago, the crunchiumo said:
i believe the ergotech triple monitor stand will fit two of those. both linus and jay have a review on it. a ultrawide is smaller in length to 2 27" panels so youll be fine
https://www.amazon.com/Ergotech-Triple-Monitor-Telescoping-100-C16-B03-TW/dp/B00DXFEAK0/ref=sr_1_fkmr0_1?ie=UTF8&qid=1479763116&sr=8-1-fkmr0&keywords=ergotech+triple+vesa
U mean this
So 34inch and 28inch should fit right
https://linustechtips.com/topic/694288-vesa-mount/#findComment-8898827
I was think of ultrawide middle and left side is the 28inch
https://linustechtips.com/topic/694288-vesa-mount/#findComment-8898837
1 minute ago, CapedCrusader21 said:
I don't know for sure so I would submit a question in the section on Amazon. You could probably get a 3 monitor mount and only use two if you wanted as well.
Here is this one https://www.amazon.com/Ergotech-Triple-Monitor-Telescoping-100-C16-B03-TW/dp/B00DXFEAK0/ref=sr_1_fkmr0_1?ie=UTF8&qid=1479763116&sr=8-1-fkmr0&keywords=ergotech triple vesa&tag=linus21-20
https://linustechtips.com/topic/694288-vesa-mount/#findComment-8899549
