i have an ocz 750w that has worked for 3 years, no fault
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8894653
5 minutes ago, Xomentrifus said:
Im looking for one for a lower power, lower budget build.
Dont go cheap on PSU. Its a good investment especially if you're planning to use your PC long term. Go for EVGA G2.
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8894700
The Jupitor Power 600W (ATX-JP600W) is a Andyson "AD-F620A2-36 (YY)", same as the Roswill Glacier M, Aerocool K-CAS and Strike-X
The Jupitor Power 800W (ATX-JP800W) is an unknown OEM.
The Jupitor Power 1000W (ATX-JP1000W) is an Andyson "AD-K1000AE-D6"
The rest I wouldn't touch with a 10 foot pole since they are not 80plus certified.
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8894708
I'm also putting together a build. So many places i've looked at online point to the EVGA G2 models (i'm putting a 750w in only because for some reason the 650w isn't available in my country).
Had looked at the Seasonic Prime 650w, but the G2 is much cheaper.
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8894725
4 minutes ago, Xomentrifus said:
I dont need that much wattage for my build. With 430 watts im good. I just need to know about an affordable yet efficient power supply
EVGA G2 550W my friend. It has 7 years warranty.
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8894740
16 hours ago, Xomentrifus said:
How do i know if a power supply is of good quality? Are apevia ones of good quality?
You read reviews of it or of the unit it's based on. If you can't find anything about them then don't buy them. That said, check out the PSU whitelist in my signature before buying a PSU.
What are the specs of the system you're powering?
https://linustechtips.com/topic/693948-good-power-supply/#findComment-8897776
