So I've got an issue where Ethernet is not working. I've tried different cables nothing seems to work. I've tried to turn off and turn it on, not difference what so ever. Wireless works fine by the way.
What shall I do? :(
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/
6 minutes ago, manikyath said:
call BT, and tell them to get you a new box.
at least, that's how things go with my ISP and their modem/router combo's o.O
Not the account the holder. My dad is and I'm only visiting them. I don't live with them at the moment. I'm living in Birmingham. So That's the problem. :/ And my dad isn't in the country, he will be back on Thursday.
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8894481
Hello fellow Brummy :P
Look at 192.168.1.1 and then see if it detects that ethernet devices are connected. See if there are any options in the advanced that are turned off/on.
I am still using a HomeHub 3 (only as an access point) so I do not really know the newer Smart Hub GUI.
Good luck :)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8896264
Good luck :)
Brummy. :D well as soon as I connect the Ethernet cable. Nothing happens. I've tried different cables. :( There are no options. The smart hub isn't smart..
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8896281
Haha yeah, the "not so smart hub" :P
And there are no lights at all???
Is there another device to try with the ethernet port on the router?
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8896294
No lights coming from the laptop LAN port. Yes, I've also tried the Ethernet cable with a different laptop. Same issue.
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8896418
Hmm, I would log into it using the WiFi and seeing the status of the ethernet from there. I take it you have tried different ports on the router itself as well?
The only other way is contacting BT :/ Which is kinda out of the question.
https://linustechtips.com/topic/693922-bt-smart-hub-lan-issues/#findComment-8896428
