Headphones advice
I make music and would like to improve my gear. I know that mixing on headphones is not that great but i cant use speakers (open back headphones are OK though) because of my family. What headphones would be the best ones to get for under $100. (I could go to max of 110 or 155) I've heard great things about Grado, Audio Technica, and Senheiser but if you guys know of anything else that is also great.
I'm just a random teenager from New Jersey. Why would you listen to me?
https://linustechtips.com/topic/693902-headphones-advice/
Personally, I love the Hyper X Cloud 2 and Plantronics Backbeat Pro headphones.
But since you're professionally making music, I would suggest headphones that reproduce the sound as exact as possible and for that, I'd suggest any audio technica - as high as you can spend. They have quite the rep.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894326
Hyper X and Plantronics is nothing for making music
, right :)
and audio technica is realy nice but allso more on the listening to music side and not so much on the super exact reproducing etc side
at least in the lower budget range
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894338
, right :)
If that's true, then I have no idea. I have always thought of AT as the best bang for buck at the low end for headphones which reproduce sound as exact as possible, without any extra emphasis. Then again, I'm not much of an audiophile.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894436
I would consider my sleeve as an audiophile (and I am a music producer)
and my personal expirience is that AT are realy good but Bayerdynamics, AKG, Sennheiser etc tend to be a little more neutral at this price point.
but as everything with sound this is very personal opinion based
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894470
I consider my sleeve a grammarphile :P
Can't ague with you on AKG. I recall owning one of their bluetooth headphones. Looked like: https://www.amazon.co.uk/AKG-Premium-Foldable-Over-Ear-Headphones/dp/B016ON147O/ref=sr_1_10?ie=UTF8&qid=1479692532&sr=8-10&keywords=akg+headphones
It was flawless.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894580
Though I ended up returning it for a reason I cannot even remember anymore. But when it came to sound reproduction, I literally has no criticism. I was looking for something more bassy but that was just me.
Yep akg is nice but this line is allso not made for the audio
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894597
I have a pair of Sennheiser HD 518s that I love. They're only like 80 bucks USD too :D
Project Hephaestus
Intel Core i5 6600K @ 4.2GHz~ASUS Maximus 9 Hero~32GB DDR4 @ 3200MHz~ZOTAC GTX 980 AMP Ed.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894681
ATH m40x.
They should get the job done :D
Cpu R5 1600 @3.7ghz - MB Gigabyte AB350 Gaming 3 - RAM Corsair Vengeance LPX 8GBx2 @3000mhz - GPU Palit GTX 1070ti Dual - Storage Kingston FuryX 120GB SSD, WD 500GB Green HDD, Seagate 1TB HDD - PSU Seasonic X650 - Case Sharkoon S25-W - Display Zowie XL2411 - Peripherals Filco Ninja Browns, Zowie FK2 & Qck Hyperbeast Ed.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894712
yes
10 minutes ago, nicobombai said:
ATH m40x.
nah
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8894760
22 hours ago, Metallus97 said:
When I am mixing on headphones I am using HD700s with a focusright amp
so first question: headphone amp present? Or using the integrated mobo stuf?
No I don't have an AMP. if i could get one for like $20 then I would, but i have never seen one that cheap.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8899531
Yeh for 20$ you can simoly use your internal stuf...
Sennheiser HD 559 is 150$ and will do a nice job of reproducing the sound pretty accurate Even not being a "studio headphone"
if if you want something wich is called studio headphone. Then get the AKG K612PRO
they are allso 150$ and allso nice but have 120Ohm wich is pretty stiff to drive for an normal crappy sound card on a mobo
I know this is your total max budget, but headphones for mixing should ba at least around this price spot.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8899786
150 is above my prices. I have heard good things about the Grado sr60 and sr80, do you know anything about those?
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8899861
what about getting some classic studio headphones? The MDR7406, they should be just fine for mixing, you still find them in studios, so yeah.
I have seen the k612 in studios, but they are above your budget.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8901390
My only concern about the Sony's is that they dont look so comfortable.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8905298
The problem is, cans within your stated budget tend to have exaggerated signature sound, like they tend to be bass heavy to cater to popular consumer taste (because that's where the money is at). The ATH-M40X, while having less bass than its more popular M50X sibling, is not exactly neutral sounding (someone correct me if I'm wrong). The only neutral'ish Audio Technica can I've heard thus far is the ATH-R70x, ever so slightly boosted bass, none of that forward sounding mids that Audio Technica cans are known for, and mildly tweaked treble which sounded mildly veiled to me (I'm an unabashed treblehead). I'd been using my Fostex HP-A4 only, which tend to warm up the sound, will try my Oppo HA-1 over the weekend.
Only at higher price bracket would you find cans that cater to.......let's say, a more specific/refined audience. The Sony MDR7506 is pretty good given its price tag, if you want something more neutral sounding, you may have to pony up some more moolah. Of course, I can't say with any certainty that there isn't a can within your budget that would ideal for you given the sheer number of cans available within your stated budget, perhaps you could look around, find something that piqued your interest and link it here. That way, the audio bigheads here (like Dackzy, SML, Dark Wizzle, KaminKevCrew) can weigh in on their opinions. I'm pretty new at this, so I'm still learning.....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8906194
What's a "neutral" headphone? I think the best one can hope for is a reasonably "uncolored" headphone. Yes, there's a difference.
I would opt for AKG K612 Pro, here. They have a nice smooth signature all things considered, except for a little zing up top. My concern with the Sennheiser HD5xx line is that they may be thick enough in the low mids/upper bass as to make your mix too bass light or thin.
If that's too expensive, and/or you are too scared of the K612 being too hard to drive, I would go for the Sony MDR-7506. These are reasonably close to a small set of monitors in terms of signature.
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8907069
well they aren't the most comfy headphones ever, but they aren't that bad, and as gamerdude said, headphones in this price range is usually have a fair bass boost, because that is simply where the money is at, because of the beats generation ( young people who love lots of bass)
if you can get the k612, then get them, if they are simple too expensive then get the mdr 7506
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8907086
The 612 is too expensive
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8909198
then you have one option left, the MDR 7506
https://linustechtips.com/topic/693902-headphones-advice/#findComment-8909555
