Just now, smiles rising said:
Can anyone make a shopping cart with all the watercooling parts needed for a gtx 1080 and an i7-6700k? the chassi i will be using is a nzxt h440w :) budget around 500-700 dollars
It very much depends on what you like in terms of design and looks but a good starting point would be to get a kit if your doing soft tubing and to add in a GPU block for that to start off with.
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893152
can you link a good kit? i dont really know where to start looking. i dont really have a theme, i like white stuff..
Watches and computers
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893176
I usually recommend the P360 kit since it has the better D5 pump, from there you can add in a GPU block with a couple of extra fittings without any problems.
https://www.ekwb.com/shop/ek-kit-p360
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893200
thanks! i would like the cooling to be white, do i get that from mayhem or?
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893213
Mayhems would be a good option with their pastel white series of fluids EKWB also carries a pastel that is a parntership with Mayhems. The kit does come with I think it was a clear fluid which you wouldn't use in that case if you were to replace it with white.
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893268
clear looks boring xD i want it to look cool.
https://linustechtips.com/topic/693778-cooling-parts/#findComment-8893273
