Hi guys,
So I'm "new" to computer building (by new I mean first time builder but watched alot of linus and other tech vids) and I'm building a new pc
My problem is, the pc won't post no matter what
Already did check for everything (bend pins and cable's), all fans spins and work fine, led's all light up (motherboard ones just for fancyness), but also a RED light on the top right corner light's up and says (dram)
in the manual it says "Indicates that dram in not detected or failed" so and my question's are :
-Is it ok to have just 1 stick of mem or is it required to have dual channel?
-Should i buy new RAM (2x4gb) of other manufactor?
-Should i send the motherboard back?
If someone had the same problem and found a solution please help me out.
Thank you in advance. Have a nice day
Specs:
-MSI z170A gaming m3 motherboard
-Inter i5 6600k CPU
-Crucial ballistix 1x8gb ram
-Corsair cx550M PSU
-GTX 1070 graphic card (didn't buy it yet)
-Cooler Master Hyper 212X Cooler
https://linustechtips.com/topic/693645-motherboard-ram-cpu-problem/
3 minutes ago, CakeDesu said:
Hi guys,
Specs:
-Inter i5 6600k CPU
-Corsair cx550M PSU
push it in until it clicks twice. if all else fails, RMA the ram
bregsit
PC specs: i7 4770s, Zotac GTX 1070 Mini, 16GB DDR3L 1600MHz (2x8GB, cheap Crucial RAM), Crucial BX500 480GB , 2x WD Blue 1TB, Seagate Barracuda 1TB, Windows 7
Laptop Specs: i5 5350U, Intel HD something, 8GB (probably DDR3 idk), 128GB Samsung(?) SSD, MacOS whatever the newest one is
3 minutes ago, TheRandomness said:
@CakeDesu Where do you have the RAM located (which slot)? Usually, if you're using a single stick (which is fine, btw), it should go in the 1st or 2nd slot.
I already tested it in all of them alway's black sreen
if you have 2 dimms, put them in the 1st and 3rd stick. if you only have 1 put it in the 1st slot
bregsit
Just now, CakeDesu said:
Still nothing
RMA the RAM
bregsit
1 minute ago, TheRandomness said:
2nd and 4th*
thats what i meant
ive been up since 7am yesterday....................... need. more. coffee
bregsit
Well I will RMA it, should i just do it for the RAM or mobo and cpu ?
Just to check, do you have all the mobo cables plugged in, specifically the 4 or 8 pin CPU power cable?
USEFUL LINKS:
PSU Tier List F@H stats
Yup all checked, everything looks fine just the red led on the right top corner that shines with or without ram (when the ram is in it blinks 2 in 2 sec to the cpu led when no ram is in it just the dram led shines)
just the ram since thats the problem...
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
