I keep getting a screen that says "reboot and select proper boot device or insert boot media in selected boot device and press a key" I got it after I put in a old hard drive then tried to put my old one back in. The hard drive shows up in the bios and the wires are in correctly and the boot priority is on UEFI hard disk and I replaced the data cable and the hhd is on. I dont know what to do. When I turned off my computer to take te old hard drive out (that is running Windows 7 while the original one is running Windows 10) I thought I heard a pop from the hard drive but it might have been because it was an old seagate hard drive that was really loud during operation. I don't know what to do I can't figure anything else out
https://linustechtips.com/topic/693449-hard-drive-boot-problems/
