So I've been stock with a 32bit Dell DIMENSION 9200 that my father bought back in 2007 so I thought that I will plan a friendly budget build that can suit my needs for rendering my 2d animations in a better resolution than 360p in flash, and maybe use after effects (but that maybe imposible if I don't have an Alienware Aurora, or so I've heard). So I marathoned a ton of Ltt videos and expend 5 weeks reading reviews from techradar, tomshardware and other websites/forums, in the end I determined that this would be my best choice, but I'm afraid that I'm going to end up with incompatible parts or with a mother not suitable for my porpuses. I plan to use this computer mostly for rendering animations, drawing and gaming, so I ask for your help to determine if this build would be a good option or if is going to work at all (I wouldn't be surprise if this was the case) I would appreciate your help/advice. Thanks
CPU:
AMD Athlon x4 860k (http://www.amd.com/en-us/products/processors/desktop/athlon-cpu)
Motherboard:
AsRock H97M-ITX/av (http://www.asrock.com/mb/Intel/H110M-ITXac/)
Case:
Thermaltake CA-1B8-00S1 (http://thermaltake.com/products-model.aspx?id=C_00002373)
RAM:
Kingston HyperX FURY 16 gb kit (http://www.hyperxgaming.com/us/memory/fury)
Graphic card:
Gigabyte Radeon RX460 (http://www.gigabyte.com/products/product-page.aspx?pid=5989#kf)
Hard Drive:
Blue wd wd10ezex 1 tb (https://www.amazon.com/Blue-Cache-Desktop-Drive-WD10EZEX/dp/B0088PUEPK) Did not found an official website ;-;
Optical Drive, I plan to use the ones in my old computer which are:
TSST TS-H653B HH SATA 16X DVD+RW (http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=R185827)
PLDS DH-16D5S 16X DVD-ROM HH SATA (http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=82TGC) I only found the driver website for this ones, but I think the specs are in the same page.
Power supply
EVGA 100-W1 500W (http://www.evga.com/Products/Product.aspx?pn=100-W1-0500-KR)
I again thank for your patience and your help c:
https://linustechtips.com/topic/693448-first-build/
CPU and motherboard are not compatible. Go to PCPP and start a build with an i3 or i5 and post it here when ready.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/693448-first-build/#findComment-8890197
Just now, deXxterlab97 said:
EVGA W1 is not the good psu but should be fine
... I hope you see the first two items...
https://linustechtips.com/topic/693448-first-build/#findComment-8890203
1 minute ago, Jed M said:
Use PcPartPicker... it'll save you a lot of time.
(suggesting because your motherboard and CPU are for two different companies. Motherboard is for Skylake Intel, and the CPU is an AMD)
but he said h97m mobo while linking us h110m while both does not compatible
https://linustechtips.com/topic/693448-first-build/#findComment-8890205
UPDATE!!
So following all your advice I decided to make another build (this was much much MUCH more quicker thanks to PCPP). I strongly believe that this build will be effective and it will work just fine plus it's not that expensive, I would thank if you read trough it and gave me some advice. Again, thanks for your help.
CPU
Intel core i3 (http://ark.intel.com/products/93366/Intel-Core-i3-6098P-Processor-3M-Cache-3_60-GHz)
Motherboard
Micro atx gigabyte GA-H110M (http://www.gigabyte.com/products/product-page.aspx?pid=5589#ov)
RAM
Kingstone HyperX Fury 8gb (http://www.kingston.com/dataSheets/HX318C10FB_8.pdf)
GPU
Zotac ZT-P10510A-10L (https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1050-ti-mini)
Hard Drive
wd wd10ezex 1tb (https://www.cnet.com/products/wd-blue-wd10ezex-hard-drive-1-tb-sata-6gb-s/specs/)
Power Supply
EVGA 100-W1-0500-KR (http://www.evga.com/Products/Product.aspx?pn=100-W1-0500-KR)
Case
Thermaltake v3 case (http://www.thermaltake.com/products-model.aspx?id=c_00001579)
Again, again thanks for your help
https://linustechtips.com/topic/693448-first-build/#findComment-8891685
