Welcome to the Forums!
What laptop make and model are you using? One thing you can try is to unplug the laptop from the charger, remove the battery, and hold the power button for at least 30 seconds. Then try to power it back up.  See if that'll work.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/693224-need-help-with-my-laptop/#findComment-8887850
8 minutes ago, Sukhman said:
When ever I try to boot my laptop it dosent even show the logo or go into windows or show the bios. I tried connecting it to a external display and doing a power cycle. Please help I need to access that laptop so then I can move my valuables to my pc.
It could be something bad with either the motherboard, cpu, gpu, ram, or almost anything.
If you need the data on the drive in the laptop you can take it out and should be able to plug it into a regular desktop if it uses sata, or get an adapter to run the drive to a usb connector or something.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/693224-need-help-with-my-laptop/#findComment-8887909
Have you got another Pc? if so take out the hard drive and then get an enclosure off amazon and back your files up like ASAP, then take your  laptop down to a PC store somewhere
Laptop - Dell 7559
Intel Core i7 -6700hq / Nvidia GTX 960m / 16gb RAM / 128GB M.2 SSD / 1TB HDD
https://linustechtips.com/topic/693224-need-help-with-my-laptop/#findComment-8887913
