i have a msi r9 280 gaming edition and when i try to overclock with afterburner it works just how it should work:
Coreclock 1150
Memory clock 1350
Powerlimit +0%
When i try Firestrike the overclock works and i get a better score.
But somehow the overclock goes away and it goes to Coreclock: 827 even though i set to be overclocked and restarting my pc doesn't work.
I had this before and i deleted and installed new drivers after that it worked for a day or two.
Does anyone know why?
PSU: Cooler Master GM G550M
Mobo: msi a970 g46
https://linustechtips.com/topic/693127-overclock-not-working/
Just now, M1R3LL said:
no afterwords maybe because i played bf1 and the gpu couldn't handle the overclock?
Is the GPU clock low when you are playing BF1 or after when you are just sitting on your desktop or browsing the internet? Did you make sure to save your overclock to a profile in afterburner?
https://linustechtips.com/topic/693127-overclock-not-working/#findComment-8886874
it is low when i play bf1 and i did save the profile.
https://linustechtips.com/topic/693127-overclock-not-working/#findComment-8886878
