Hi guys, I've just transferred my build into an INWIN 303 and I love it. I don't have my GPU fitted yet as the EK block leaked so its away for RMA (caught it before it actually left the block!) and I have switched from dual loop (360 + 240mm on GPU loop and 360mm on CPU + VRM's all 60mm) to 240 x 60mm and 360mm x 45 xflow. I'm aware that my previous Enermax Vegas weren't the greatest SP fans but I could get away with it with so much surface area. Now I don't think I will and have already ordered 3x Thermaltake Riing 12 fans http://www.thermaltake.com/products-model.aspx?id=C_00002638. This leaves me with the lower 2x fans on the bottom radiator to replace:
Please ignore that tube from the 240mm to the CPU block, its temporary whilst I'm waiting on the GPU block xD
So I'm aiming to balance the pressure out here, aka get some dedicated Static pressure fans which I don't need LED's for. I would prefer the fans on top of the radiator in a "Pull" fashion. The High Performance Corsair SP120 would be ideal if they Pull with the blades facing upper most, but I doubt they do.
Anyone have any suggestions?
Also if the fans are to stay in "push" I would prefer they be white for cosmetic reasons, thanks guys
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/693071-suitable-radiator-fans/
15 minutes ago, Cohacq said:
Pure performance? Noctua NF-F12. Pure looks? Corsair HD120.
Ideally I would like them on top with face up, but I need the min pull to balance the airflow through the case. Not too fussed about LED, just decent looking, not brown etc lol
Ryzen Ram Guide
https://linustechtips.com/topic/693071-suitable-radiator-fans/#findComment-8886540
There are black Noctuas available. And you can get different colored rubber pads from their website.
https://linustechtips.com/topic/693071-suitable-radiator-fans/#findComment-8930265
Thanks, I eventually went with Ek varders in push, yet to see if they've made a difference as I dropped the coolant again to do some work. Had to drop it anyway as routing the fan cables required me to move out the radiator to be able go behind the motherboard
Ryzen Ram Guide
https://linustechtips.com/topic/693071-suitable-radiator-fans/#findComment-8930437
