I have a nvidia GTX 750ti
A6 6400K Richland APU
Gigabyte F2AH68M-HD2 Motherboard
I'm thinking of overclocking my graphics card for the first time.
If i overclock it without increasing the input voltage, will it damage my motherboard? like fry it completely?
https://linustechtips.com/topic/693014-does-overclocking-damage-motherboard/
You just don't have a lot of room for more power delivery. It won't blow up, you just won't get a crazy overclock. Try it and see how far you can get. I wouldn't mess with voltages though unless you're undervolting
That's an F in the profile pic
If you don't have supplemental PCIE power then it's best to leave it as it is. Even though it won't damage most motherboards, it just won't go far enough to show a significant difference
