Camera for HQ youtube vlog-like project
Canon EOS 7D with a nice lens, I know nothing about lenses and what works best with your situation, but this is the camera many television shows are shot with and almost every youtuber uses.
I think you're thinking of Canon's 5D man, and they're worlds apart from the 7D. 7D is pretty junky compared with its price point competitors.
OP, I think Sony's a65 is the best option for you at this pricepoint. You're talking about the "Agent Smith" thing, and I think you're referring to the rolling shutter issue which plagues DSLRs. It's an issue that gets exponentially worse on smaller sensors, however is particularly bad on Canon and Nikon dSLRs. Sony don't actually make dSLRs, they make dSLTs, which due to higher allowed framerates and shutter speeds basically eradicate the issue completely.
The 18-55 kit lets is an okay way to start. Some things to google are softboxes with diffusers (for lightning) and don't forget your spare batteries, memory cards, etc. There are already probably 50 posts like this on LTT forum, so use the search feature, most of your questions have probably been answered.
