Hey,
Currently owning an OCZ ZT 750W 80+ Bronze certified PSU. I'm going to give this away to my father, and was thinking of buying a Corsair RMX PSU. My setup consists of: i7 4930K (4,2GHz OC / 1250V) + overclocked GTX 1070. I'm not sure if I should go with the RM650x or RM750x. What do you think?
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
https://linustechtips.com/topic/692719-will-650w-be-enough/
1 minute ago, STRMfrmXMN said:
650W is more than double what you need.
By that definition, I could go for the lowest in the RMx series, the 550?
HWBOT
https://linustechtips.com/topic/692719-will-650w-be-enough/#findComment-8883244
That's what I'm using. Works perfect. 500-550w will be more than enough. Good to have a little extra to upgrade in the future.
My Current Rig:
CPU: Intel Core i5-6600K CPU Cooler: Cooler Master Hyper 212 EVO GPU: ASUS STRIX OC 1070 Motherboard: MSI Z170-A Gaming M5 Memory: Corsair Vengeance LPX 2 x 8GB DDR4-2400 Storage: A-Data Premier 240GB SSD/Seagate Barracuda 2TB 7200RPM Case: NZXT S340 PSU: Corsair RM750i Monitors: Acer R240HY/ Dell S2716DG
https://pcpartpicker.com/list/xwcjLD
https://linustechtips.com/topic/692719-will-650w-be-enough/#findComment-8883264
3 minutes ago, pwn_intended said:
If the price difference is a couple bucks, go with the higher rated one. If the difference is like $25 or more, then you can just get the 550W.
Agreed Mr. Chief. Waiting for Black Friday :)
HWBOT
https://linustechtips.com/topic/692719-will-650w-be-enough/#findComment-8883310
Easily.
https://linustechtips.com/topic/692719-will-650w-be-enough/#findComment-8883433
